Exterior Tint on entertainer coach
Guest magnum24_00
Guest magnum24_00
I have a tinting problem and here it is. I have a entertainer bus that I need to figure out how to tint the EXTERIOR windows on my coach. I cannot tint the interior because when the bus was customized, they built walls on part of the window going down the side so I cannot get to half of the window and half the window would be tinted and the other half not tinted- very tacky looking. I would rather not tint the windows than have that look. I just want something to keep down the tempurature in the bus from the sun. Basically what I am asking is if there is anyway to tint the exterior-Any suggestions?
Guest Total tint
no the tint isn't going to last for one, due to the outside elements, rain , bugs, snow etc.and if you found a place to do it you'd want to stay away from them any way
Guest Total tint
Yeah, if there is enough room to fit a slim, long reach tool you could probably do it.  Even if it's doable, it's going to probably cost you an arm and a leg just for the added headache the installer will be going through .
[*]258935
:thumbdown
I'd probally charge the same as I charge for 5 cars to do it
Guest magnum24_00
There is no room between the window and the wall to get to the other portion of the glass window. Is there any kind of spray on application that can be done to treat the exterior windows?
here is an exterior photo of the coach
