Guest Total tint Posted January 12, 2005 Report Share Posted January 12, 2005 having a problem keeping dirt out of the back windows of old trucks doesn't matter how much I clean there's still dirt any tips Link to comment Share on other sites More sharing options...
Guest GeorgiaTinter Posted January 12, 2005 Report Share Posted January 12, 2005 I try to aviod getting those old upper gaskets wet, they tend to keep "bleeding" dirt out. I spray down and away, never flushing the gasket out, works well for me. Good luck. Link to comment Share on other sites More sharing options...
TintDude Posted January 12, 2005 Report Share Posted January 12, 2005 I try to aviod getting those old upper gaskets wet, they tend to keep "bleeding" dirt out. I spray down and away, never flushing the gasket out, works well for me. Good luck. [*]244814 Link to comment Share on other sites More sharing options...
Guest nautiboi73 Posted January 12, 2005 Report Share Posted January 12, 2005 trim gasket trim film 1/16 smaller on all sides. use dry paper towel on all edges with hard card. that should help Link to comment Share on other sites More sharing options...
Mr paladin Posted January 12, 2005 Report Share Posted January 12, 2005 the last one I did I cleaned all the rubber seals best I could, dryed it with a heat gun then coverd all rubber all the way around with masking tape, when ready to install the film I do not wet the back glass only the film ,this keeps dirt from dripping down Link to comment Share on other sites More sharing options...
TINT Posted January 12, 2005 Report Share Posted January 12, 2005 old trucks? depending on how the gasket is, I just pull them out. after its done, cleanest job you'll ever see. Link to comment Share on other sites More sharing options...
Guest thetintshop Posted January 12, 2005 Report Share Posted January 12, 2005 I only do old trucks if the gasket is not dry and brittle so I can remove it. if it is too brittle, I make them buy a new one from me. if they refuse to buy a new one, I send them on down the road. not worth my time or my reputation to put out something that doesn't meet my standards. Link to comment Share on other sites More sharing options...
TINT Posted January 12, 2005 Report Share Posted January 12, 2005 that's what I say, if they say "oh just do it on there" I say no because if something they see they dont like, it falls on me. screw that. Link to comment Share on other sites More sharing options...
blade Posted January 12, 2005 Report Share Posted January 12, 2005 If I can't take the back window out because of the old gasket then I do like NB and trim the gasket back a bit. Link to comment Share on other sites More sharing options...
tintnfool Posted January 12, 2005 Report Share Posted January 12, 2005 I do the same as Mr. P, only I don't tape the seal. Dry it up with the gun after towel dry with a card wrapped up, and only wet the film Link to comment Share on other sites More sharing options...
