Guest AutoAppearancesInc Posted January 6, 2005 Report Share Posted January 6, 2005 (edited) Hello: No PPF work for months and now I am getting installs like crazy!!! I also have a ( <snip> ) Install on a 2005 vette. The only issue I see is THAT HUGE MIDDLE and LOWER Bumper sections. I ordered the kit with the middle and lower sections joined. No Split sections. What is the best way to install these sections? I was thinking of doing the following . Get it lined up with the turn signals. Tack it in the center. Then work on one side lining it up with body lines. Then do teh same on the other side. I am really guessing on this one!!!! Any Advice on this one too? Thanks in advance. Edited January 12, 2005 by AutoAppearancesInc Link to comment Share on other sites More sharing options...
Guest kccartint Posted January 6, 2005 Report Share Posted January 6, 2005 That method seems to work well. Should have no problems. Link to comment Share on other sites More sharing options...
Guest dtm61 Posted February 9, 2005 Report Share Posted February 9, 2005 That method seems to work well. Should have no problems. [*]242167 So how did that 05 vette turn out going that way I have one next week and I'm having second thoughts ........ any advise from any Link to comment Share on other sites More sharing options...
Guest Clear_pro Posted February 9, 2005 Report Share Posted February 9, 2005 I did one this last month and it turned out wonderful just use what you know and you can get through it. If ever in doubt on how to do an install take it slow, don?t be in a rush. Every design house has there own way to install there kits. Figure out what the designer?s intent was weather you start in the middle or coast to coast play with it a bit. I attached a Picture of the final product if you would like to see Good luck Link to comment Share on other sites More sharing options...
