how wide?
Guest bdepew
I think Hanita makes film 80 or 84 inches wide, however, I'm sure the selection is limited.
Don't know of any other and would be a little hesitant to use it because of some of the old issues that 72 inch film had may play out in much wider film. :thumb
Guest TintPoser
so say you have a 80" X 120" window? what do you do?
[*]238350
I have only seen it once, but this is not an IG is it?
Seam it wherever the customer wants the seam. Sometimes we seam it right down the middle, other times we seam 72" from the top.
[*]238350
Depends on the film being used. Sometimes splice it, sometimes overlap it, if the window has a grid in the it...hide the seam behind one of 'em. Sometimes vertical seam, sometimes horizontal.
Don't know of any other and would be a little hesitant to use it because of some of the old issues that 72 inch film had may play out in much wider film. :passout
[*]238312
I?m looking for a 80? or 84? wide in security film. 8 or 10 mil clear. Could you refer me more about Hanita?? I need a roll of 100 ft Tank?s :music
    rxactlite.com
    rewiredtech.io
    2. 2
    3. 3
    4. 1
    5. 2
    6. 1
    7. 3
    8. 3
    9. 0
